Soft flybridgd floor
I saw on line a product that says it fixes soft spots without ripping up floor its called injectadeck anyone use it
- Stripermann2
Re: Soft flybridgd floor
I searched their site, kinda hokey, I thought.
Do the job right and get the rotted coring out and repair. You can search this forum or if you're on FB, there is a Trojan Boat Owners page. Bob Cushman here at Trojan Boats (Beacon) has a link to some good material to replace the balsa core. I have to do mine at some point...
https://www.facebook.com/groups/127978997244792/
http://www.tricelcorp.com/marine/
Have not used it but was going to give it a try. Did you try it?
i used a similar product called Git Rott, waste of time and money for my application, soft floors at the top of the ladder
- Beacon Bob
Here is a good number for the Tricel board
Vacuum Systems Co.
207 725 0935
Pricing 2’ x 4’ sheet
1/2 $13.30
3/4 $18.66
1” $22.50
Vacuum Systems Co.
207 725 0935
1/2 $13.30
3/4 $18.66
1” $22.50
- Beacon Bob
Photos of Tricel
- 00A674AE-49EF-466E-A97F-52B3D4778790.jpeg (33.69 KiB) Viewed 9271 times
- 9B7CD855-C597-4633-8658-B1A8B6D17573.jpeg (58.58 KiB) Viewed 9271 times
- WayWeGo
Bob, how do you avoid the resin flowing down into the core? It seems like it would fill up and get very heavy.
- Beacon Bob
We would use a micro filler to make the resin into a glue or paste.
You Do Not want to fill the Tricel with resin.
Then we would glue the Tricel to the bottom sheet of fiberglass and the top sheet of fiberglass.
This is very basic instructions. Please feel free to call us
Beacon Marine
Trojanboats .net
609 713 4602
Beacon Marine
Trojanboats .net
609 713 4602
- Beacon Bob
There is also
Airex Boat Structural PVC Foam C70.75 | C70 42 x 24 x 1/2 Inch Green
About $50 for 2’ x 4’
This is 1” squares like the balsa core.
We have used this when replacing the balsa core in a soft spot on a hull ( not a Trojan)
- Beacon Bob
Note:
Balsa core and foam board core material is generally in 1” squares or rectangles and available in standard sizes 1/2” 3/4” and 1”.
The thickness of the product you use for coring is important.
Generally on soft spot repairs the top piece of 1/4” fiberglass decking is removed and new core material is added.
*The same top piece of original 1/4 fiberglass decking once prepped is returned to its same position.
The depth of the material used to replace the balsa core need to be the same thickness 1/2”, 3/4”, 1” as what is removed or the top fiberglass will not fit back in place.
Trojan did not use any odd thickness of balsa core.
1/2”, 3/4”, and 1” were the thickness of the balsa core.
Beacon Marine
609 713 4602
Beacon Marine
609 713 4602
- Beacon Bob
And a picture of wet balsa core.
Note: The black in this picture is balsa core that has begun to rot. The black balsa will turn to mud in it final stage of rot.
The lighter shades of black are wet balsa which will in time turn to black mud.
- 100B15BE-20AA-47DD-9284-C3E8F7AE0A6E.jpeg (35.27 KiB) Viewed 9117 times
- Beacon Bob
Wet balsa
- 582738FA-8309-4D5D-A9C5-455059B6FF58.jpeg (35.27 KiB) Viewed 9116 times
