Siezed Engine Drain Plugs - Alt Method to Drain Coolant
36 Tri
Post by 36 Tri »
Hi,
Can't get the drain plugs out of the manifolds nor engine to flush the coolant antifreeze. Can I just hand pump out most from the cap (snake down small tube), then remove tubes from thermostat and pump out from those locations?
Most is better than none?
Thanks... John
1970 Trojan 36' Tri-Cabin, Crusader 270 engines (350 small block)
2024 Gold Support
2024 Gold Support
Re: Siezed Engine Drain Plugs - Alt Method to Drain Coolant
Post by larryeddington »
careful I had some stuck ones in Chryslers and some twisted off and had to used chisel to get the leaves out. I bought a set o 8 point sockets to use on square plugs and use 1/2 extension to turn internal plugs. Lot o extra work but got them out. Replaced with brass ones.
