Rear windows on my 75 F32 sedan
- AwayOnBusine$$
Need to replace the rear 2 windows on both sides. Any ideas of best approach or where so source. Any body parting a F32 where the glass can be salvaged.
F32 Fly 1975
- AwayOnBusine$$
- AwayOnBusine$$
- Moderator
Re: Rear windows on my 75 F32 sedan
Check with Beacon to see if the have any . if not a local glass shop should be able to make/cut what you need .
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
Are you talking about the 2 aft 'sliders' on the sides, or the big panes on either side of the sliding door?
If the first one, glass can be cut by someone local if you can take them what you have to be used as a template, and Beacon can walk you through how to get the existing ones out and new ones in (they gave me the 'talk' when I ordered new H channel from them).
If the second one, maybe folks who have done engine replacements, and may have had to pull the glass out to get the engines out/in, can coach a bit.
- AwayOnBusine$$
It's the first/ and actually could use the back 3 on the port side. Have the H channel already. Just looking to save some bucks.
Thanks for the response.
F32 Fly 1975
For the life of me I can't figure out what h-channel you guys are talking about?
- AwayOnBusine$$
H-Channel is the replacement for the top and bottom channel the allows the window to fit in the section were the window sits. This fills the space so the widow fits the reservoir. Bob at Beacon can give a much better description of the process.
F32 Fly 1975
Its basically the edging for the sliding window panels that holds the glass on one side, and slides along the guides in the window frames on the other.
Here is a picture of it https://www.trojanboats.net/zencart/ind ... cts_id=199
And here is a thread that talks a bit about it viewtopic.php?f=1&t=1624
And another viewtopic.php?t=7764
Thanks guys for the links to the explanation… Now I get it...
