Question: 1990 12 Meter
Have Shore Power 1 & 2 Connected and Power Panel is registering
Shore Power connected as OK (indicator lights show proper connection)
Shore Power 2's indicator lights are flickering and at times showing no lights.
Both Power "Meters" however are showing same power to Shore 1 & 2.
Here's my delema;
With both shore power 1 & 2 connected (as shown above) the boat is not getting power to it. No power to any of the accessories, fresh water pump, outlets, lights, nothing........ unless I flip the "Charger" switch on the panel to ON, then everything comes on.
Is this correct?
With my other boats, I was always under the impression that be it the Battery Charger was ON or OFF, when on Shore Power, just #1 or both #1 and #2, everything fired up.
Not the case here...
Any insight or lesson on how the 12-Meter should operate in this situation is much appreciated.
Thank you,
/Murray
12 Meter Power Electrical Question
