boat renovations
I never got around to finishing the trim work after I replaced the deck last summer. Here is what I have done so far. Once everything is fitted I will remove it all again and apply the varnish.
Still thinking about built in seating at the back of the boat. If any one has any good ideas I would love to hear them or better yet post some pics.
- lawyerdave71
- jblack1036
fridge interior door panels
Awsome job Gumper. I'm curious to know where you found the replacement fridge interior door pannels. PO cut them out of ours so I have no shelves to put stuff on and the bear foam without the skin doesn't look good no matter how you look at it when you open the fridge.
Jim Black
31' 1965 Trojan Sea Breeze (Wiskey Girl)
29' 1974 Caver Monterey (Rough -N- Ready)
Don't know if I will be able to find any pics or not, but we built a bench seat in my father's old 28' years (actually, decades) ago. It was a simple short bench on each side of the aft hatch, that covered the space from the hatch to the cockpit sides. 2x2s for framing I think, and then used a 'grid' of 1x2s or 1x3s for lower shelves and seating surface. 1/4" ply for a 'face' for each of these sections.gumper wrote:Still thinking about built in seating at the back of the boat. If any one has any good ideas I would love to hear them or better yet post some pics.
There was also a removable section that joined the two mini-benches. It was also a grid of the 1x2 or 1x3, and just lifted off when you needed to get in or out of the aft hatch easily. Kind of worked like the filler section in your v-berth.
On top of it all was just a vinyl-upholstered 2" foam cushion.
Gave us seating, plus increased storage (life jackets, BBQ, etc). The 'shelves' also kept whatever was stored there off the ground (and dry from rain or spray running through the cockpit to the scuppers) and the grid design also let air to everything.
Anyways, will see if I can find any pics from way back then, otherwise may try to sketch something up.
bench seating
Thanks captainmaniac I would appreciate pics if you could find them. There are not many Searaiders around here any more. It is hard to find pics of what other people have done. My boat has had alot of repairs over the years. I don't know what is original and what is not.
I am sorry jblack1036 but those are not new frigde panels. I wanted to keep the character of the boat as much as possible. I love the wooed doors on the fridge. After 40 years the plasitc panels had cracked and the baby blue colour thats " color" for our american friends had faded and stained.
I removed all the panels and seals front the fridge and used fibre glass and west sytem expoxy to rebuild the inside door panels and repair the inside of the fridge. I then put 6 coats of paint and wet sanded the panels up to 2000 grit paper. I then polished the panels. The metal bars that hold the stuff on the shelfs go into the panels about a 1 1/2" from the front instead of just going through the sides. It made more room on the shelf and is stronger. This was my winter project last winter.
I am sitting in my shop in the back ( the shop is so old that the city does not know when it was built. I found initials and the year 1891 carved into a board) and I was staring at the old teak hatch covers that I saved when I did the deck last year. They were in much better condition than the deck just could not justify the cost of using teak on the new deck to match them. I was thinking that one would make a great table to go with the new bench seating.
I know there are a few of you guys in the Toronto area. Do you know were I could find some teak lumber there. I have not found a good source here in Ottawa. I am going to a company function at the harbour castle hotel in a month thought it would be I good time to pick some wood up.
