so theoretically, if the rudder shafts wee removed...
the boat is in he water...
at the dock, at rest
no water will come itto the boat?
Is this a correct assumption?
International Rudder Shaft Seals
- Beacon Bob
YES THAT IS CORRECT.
IF YOU THINK THE WATER IS COMING FROM THE RUDDERS YOU COULD TRY TIGHTENING UP THE BOLTS ON BOTTOM. THEY SCREW INTO A BACKING PLATE. IT SHOULD BE EASY TO TELL IF WATER IS COMING IN FROM RUDDER BOLTS SINCE THAT AREA SHOULD BE ALWAYS DRY WHEN BOAT IS NOT UNDERWAY.
- Beacon Bob
IF THERE IS WATER AROUND THE RUDDER POSTS THEN REMOVE ALL THE WATER AND INSPECT THE BOLTS FOR WATER SEEPAGE. IF YOU FIND SEEPAGE OF WATER THEN TRY TIGHTENING THE BOLTS. IF THIS DOES NOT STOP SEEPAGE THEN WE WOULD SUGGEST REPLACING THE NYLON BLOCKS.
