remeber to run the blowers or ...
just a reminder Always use your blowers and siff for gas . one boat blew up to day near by .
http://hamptonroads.com/2012/06/several ... -explosion
I was just there working on the bayliner, darn news crews were filming us. I took pics of the boat if you'd like to see them, 2 badly injured. dock hands said the 2 guys sitting on the engine cover were thrown 20 feet in the air and landed on the windshield of the boat. My wife dispatched the rescue call, then called me. I was already planing on going out there to work on my starter after work. Its sad. I didnt want to be on the news but I think I probly will be. They seemed interested that I was working on the motor. 4 guys had just fueled up and started out of the marina when she blew up, was a very sobering evening for me at my spot. The boat still smells like its burning.
mine are mounted towards the keel 4" above the bilge one on port fwd and one stbd aft.......reminder when's the last time you checked the fill hose from the deck fitting to the tank ?
I looked at those fill hoses just last weekend.....ugh..........numerous cracks but not leaking YET. They are very rigid to put it mildly (OEM????). That's one job I think I'll bite the bullet and get someone else to do. Along with new ground cables. I'll have to get a quote from the marina service dept. Probably another $500 +.
1978 F-28
I love the sniffers....have one in the engine room and one @ aft fuel tank. They work perfect..... the engine room one went off after a backfire and the rear one went off when I spilled maybe 5 drops of gas while changing my fuel back flow preventers
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
And for us gaser's running your blowers after running the the boat is just as important. Having a mid-engine boat if the engines and engine room is hot the gas in the carb's flumes off out of them, running them pulls the flumes and helps cool the space down...
Thanks Tony - never thought of running the blowers after shutdown. Good advice.alexander38 wrote:And for us gaser's running your blowers after running the the boat is just as important. Having a mid-engine boat if the engines and engine room is hot the gas in the carb's flumes off out of them, running them pulls the flumes and helps cool the space down...
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
I would hope everybody here knows to stick they're nose deep down into the bilge before every start.
+1 on Tony....I usually run mine about an hour after shutdown....removes heat also and that funky smell of hot hoses!
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I know this is a month old thread, but I am new to the bigger boat situation and learn from you guys all the time.
When I refueled a week ago I had hatches open looking and smelling... Partially because I could not believe how much gas she took!
On a serious note, running the blowers after shutdown is a great idea, and will start doing it today.
1072 14 ft Meijers - Sears outboard
1990 17 ft Sea Nymph - 70 Johnson
1992 17 Tracker Deep-V - 40 Yamaha (still own)
1987 266 Cruisers Inc - 460 King Cobra
1974 F36 Trojan - Twin Crysler M400
