Can someome else to to post a reply to that topic and see if it is successful?
Every time I try I get this...
You don't have permission to access /wforum/posting.php on this server
I have now tried on my home and work computer with the same results.
Posting a reply to the pumpout deck fitting topic
- Stripermann2
Just did. No issues. But...I have had this problem in the past. Try logging out, then logging back in. Otherwise, send a pm to the moderator and Don will check into it.
- ready123
I believe this is caused by a specific string in your post (can't remember what) try adjusting the text content. Captainmaniac has discussed this before... try a search on posting error and him as author.
Re: Posting a reply to the pumpout deck fitting topic
It happens when you try to use a particular character, just can't remember which one. Thought it was quotation marks but just tried and it worked; must be a different one.Jerry wrote:Can someome else to to post a reply to that topic and see if it is successful?
Your right , wish I coud remeber what character or wordBig D wrote:It happens when you try to use a particular character, just can't remember which one. Thought it was quotation marks but just tried and it worked; must be a different one.Jerry wrote:Can someome else to to post a reply to that topic and see if it is successful?
Jerry email me what your tring to post and I will figure it out .
