12 meter trim tabs
Counterfitter
12 meter trim tabs
Post by Counterfitter »
I had recently purchased 89 12 meter express with 671 Detroits boat rides bow hi . my trim tabs are 18 " span with 20 " chord can anyone that has this similar model tell me what works pictures would be appreciated
2024 Gold Support
2024 Gold Support
I can't really awnser the tab question . But a while back you were having a performance issue I believe . Did you get that sorted out ? It may not be a tab issue.
What rpm are you getting at wide out throttle ? and what speeds are you getting ?
Counterfitter
12 meter trim tabs
we ran the boat for 7 hours to get it home it ran 18 knots @ 2100 rpm s that's about the highest I've seen
we averaged 16 knots at 1800
bow high all the way
Commissionpoint
Post by Commissionpoint »
Revs sound decent, speed a bit slow. Clean running gear? Props in good shape? Tabs on the boat now running properly through their whole range and holding pressure? Those are some easier things to check before going crazy trying to figure it out.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
alexander38
Re: 12 meter trim tabs
Post by alexander38 »
has it always rode high ? how much stuff have you packed on her ?
