vacum drying?
vacum drying?
I have read some posts that mentioned using a vacuum to dry out cored decks. My question is: I have lots of little screw holes in my hardtop, what would be the best way to seal it to hold a vacuum?
“Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.â€
Albert Einstein
Albert Einstein
Re: vacum drying?
I would try aluminum foil tape, as used in HVAC Business, strong and when pressed down with sqegee is seals. I have it temporary over the holes where my anchor storage parts were.
Re: vacum drying?
If you're talking about how to hold/seal clear plastic to the surface you're vacuuming, you can use puty around the perimeter or two sided tape. There was a thread on this that I posted a link to and showed this, I just can't remember where it is.f32ms wrote:I have read some posts that mentioned using a vacuum to dry out cored decks. My question is: I have lots of little screw holes in my hardtop, what would be the best way to seal it to hold a vacuum?
Re: vacum drying?
2 sided tape sounds like the ticket.
Albert Einstein
Albert Einstein
