1972 F-26 Cutlass Bearing Size?
vabeach1234
Post by vabeach1234 »
Well I'm gonna haul the boat soon to replace the prop, zincs and such. I figured it's probably time to replace the cutlass bearing (have a vibration) but I don't know the exact size I need. I know the shaft is 1" diameter but I'm not sure of the length or outside diameter of the bearing. I'm guessing that it's a 1" inside dia. X 1 1/4" ouside dia. X 4" long but I can't verify that until I'm out of the water. I'd like to order the bearing before I haul the boat so I can spend less time on the hard. Does any one know the exact size of these things for this particular boat?
This is where I plan on ordering the bearing:
http://www.deepblueyachtsupply.com/series.aspx?id=2
Thanks,
Ken
1972 Trojan F-26 Hardtop Express
Chrysler 318 FWC
Paragon V-Drive Trans
Norfolk, VA
http://www.putfile.com/vabeach1234/images/98775
c abbott
I cant help in this but could use pics of engine cooling to
Post by c abbott »
got a boat and started replacement with used engine seems I may have closed tranny system with open cooling system ...if u have pics it might help me identify what goes where ... the previous engine was out already so Im cornfused??? I have a 26 cruiser with 360 chrysler
1972 trojan
vabeach1234
I have some info that I've found over the years regarding the cooling system for the 318. Send me your email and I'll send you what I have.
Pictures of my engine:
http://www.putfile.com/vabeach1234/images/9734
http://www.putfile.com/pic.php?img=5451762
A pdf file I found on Chrysler cooling: (good stuff)
http://www.coastalcafe.com/images/troja ... iagram.pdf
I have some diagrams of the various cooling layouts but my putfile keeps deleting them I guess because they are copyrighted.
Ken
1972 F-26 Trojan Hardtop Express
318 FWC Chrysler
Paragon V-Drive
c abbott
72 trojan 26
Post by c abbott »
thank you for your input I am slow with download etc I just wanted to let you know I appreciate the reply and effort . craig
1972 trojan
