I just re-launched the boat again this week after reparing what I thought was the only leak I had. There was a leak at the outboard v-strut backing plate on the port side.
I just assumed this was the only spot it was leaking and only removed and re-bedded the two bolts for that plate. Now when I evacuate all of the water in the lazzarette there is a small trickle of water coming from under the fuel tank filling it back up. Has anyone ever had the fuel tank out ? Do the inboard v-strut backing plates sandwich the liner and the hull between them and the strut? Or is there a hole cut in the liner to access them like the outboard ones?
10 Meter Express Mystery Leak
1987 Trojan 10 Meter Express
1974 23' Prowler
1981 11' Boston Whaler
1974 23' Prowler
