missing bathroom door for 1989 10meter
I am missing the door and hardware for the bathroom sliding door .Could use some pics and sizes.It was not in the boat when I purchased it .I am also working on the air conditioning and considering changing from digital control to manual as the digital only flashes 8s any thoughts welcome.
1989 10 meter mid cabin
175 skeeter
17 Vanguard
13 Caesar Thundercat
Taser sailboat
175 skeeter
17 Vanguard
Taser sailboat
Re: missing bathroom door for 1989 10meter
Have you checked with Beacon Marine ?
If its the mid cabin slider from the head to the main salon, it should be easy to make a new one. The door itself Is just plywood. I just put mine back on a few weeks ago. I'll take some pics. Do you still have the tracks mounted to the wall?
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
the track is also missing .I only have the sliders.thanks for your help on this.
175 skeeter
17 Vanguard
Taser sailboat
175 skeeter
17 Vanguard
Taser sailboat
I should be at the shop tomorrow. I'll take a few pictures and get back to you
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
imo i think you might be making a mistake to go from digital to manual thermostat. what brand ac are you having issues with? what thermostat? digital control is great set the temp to what you want and be done no fiddling around too hot too cold etc.wayne 1 wrote:I am also working on the air conditioning and considering changing from digital control to manual as the digital only flashes 8s any thoughts welcome.
also i suggest that you ask only one question in a post because others that dont have any reason to click on a post about a bathroom door will miss the ac question all together since the title of the post is about the door. maybe why no one has answered anything about this yet
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
todd thanks for the pics they will help.The ac is rotary aire by westerbeke it should still have full capabilities but with manual switches.
175 skeeter
17 Vanguard
Taser sailboat
175 skeeter
17 Vanguard
Taser sailboat
wayne , I took all the measurements for you and then misplaced the paper that I wrote them down on! will get them to you soon. I do remember that The door is 5/8 plywood. I believe you can make the brackets out of a piece of flat aluminum stock. the wall track is similar to the picture on the left showing "inside track width" http://www.mcmaster.com/#door-hanging-tracks/=sywmar
but without the "J" return on the inside return. I'll get the measurement for you .
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
Ok,
stainless Brackets are 1- 1/2 inch wide x 4 inches , the top hole that connects to the plastic slide is 1/2 inch down from the top. the track is 1 inch where it screws to the wall by 1/2 inch wide. the "cut out" where the plastic slide enters is 1/2 inch which leaves 1/4 inch legs on the top and bottom.
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
Thanks Todd ,my computer has been out for tune -up
175 skeeter
17 Vanguard
Taser sailboat
175 skeeter
17 Vanguard
Taser sailboat
