Hi All & thanks for the views....
Cut my hot water pvc lines when I removed it (Had to reinforce the cabin floor from the Hull up)... was no problem, used GatorCaps for the time being to seal it temporarily until I reinstall the tank. Upon sealing that, flipped on the water and ended up completely busting the diaphragm in my water pump to my galley sink, head sink. Not too knowledgeable on these pumps. ShurFlo? 4 GPM? What would you recommend? 31ft wooden Trojan. The last pump was quite loud. Are there any that are designed to be quiet?
Thanks much for any direction you could steer me.
New Water Pump advice
L-i-v-i-n
