1980 F28 Merc 305 issue
Posted: Mon Jun 22, 2015 9:57 pm
by wetbuoy
Hi all, Managed to delete the long version of my question so here is the short. #2 engine will not go beyond 2500 rpm when under load. Neutral revs to 4000 easily. All new ignition and wires plugs etc, carb rebuilt, all cooling ok, vacuum lines, filters, timing checked. New fuel, switched tanks, control cables ok. 2 GOOD mechanics are stumped.
Anyone got any ideas? 18 months and counting, at least I had time to renovate the interior for my wife.
Thanks Wetbuoy
Re: 1980 F28 Merc 305 issue
Posted: Mon Jun 22, 2015 10:16 pm
by mikeandanne
Here are a couple ideas....if that engine is running smooth and not popping when you accelerate then check to see that the secondary throttle plate is opening all the way, if the choke is not completely off it will block the secondary linkage from opening.......now if that is opening then it may be a timing issue where the advance curve is not correct and the engine will not spin up under load.Stuck advance plates in distributor will do it.
A question...was the engine ok before the tuneup, what changed....Mike
Posted: Mon Jun 22, 2015 10:25 pm
by captainmaniac
At one point I had a problem with distributor not advancing as I accelerated. Only got a couple of degrees of advance. In neutral in the slip I could rev as I wanted to, but under load would not exceed 3000 RPM. Replaced distributor to resolve (and had old rebuilt as a spare).
Posted: Tue Jun 23, 2015 7:55 am
by BarryL
You mention that you are not having any back fires so we all assume you have the plug wires hooked up per the firing order but I recently had some work done on a mercruiser 350 and plugs 7 and 8 were switched and out of the proper firing order. No back fires and it would run smooth and rev fine without a load. out on the water it was a weak and powerless slug that wouldnt get out of it's own way. A closer look at the plug wiring discovered that the two wires were swapped and now the engine runs as it should. Pull your plugs and make sure they all look like they have been firing. A chocolate brown is what you want.
Barry
Posted: Tue Jun 23, 2015 8:55 pm
by wetbuoy
Thanks for the suggestions, I will double check the plug wires. I have brand new distributors timed by a pro. Will also re-check the advance plates. I got a marina mechanic to suggest running up to the dead spot and spray a bit of fuel into the carb and see if there is acceleration; will also try that this weekend. Thanks everyone. Steve
Posted: Tue Jun 23, 2015 9:23 pm
by mikeandanne
wetbuoy wrote:Thanks for the suggestions, I will double check the plug wires. I have brand new distributors timed by a pro. Will also re-check the advance plates. I got a marina mechanic to suggest running up to the dead spot and spray a bit of fuel into the carb and see if there is acceleration; will also try that this weekend. Thanks everyone. Steve
Just make sure that the advance curves in those new distributors are marine versions and your total timing is the marine spec.......there can be considerable damage done if automotive specs are used.....you probably have but I felt I should mention it anyway.......Mike
