led interior strip lighting
2024 Gold Support
2024 Gold Support
Post by larryeddington »
Has anyone tried the led strip lighting that comes on rolls and has adhesive backing for indirect lighting. I have fluorescents indirect in my tri cab and I think a strip on each side and color changing would be cool, mainly would draw less power. :)
Flyboy
Re: led interior strip lighting
Post by Flyboy »
Yes, I have it in my 10 Meter and it works great. The lighting is so much better and draws a fraction of the current. I highly reccomend it.
TC
Post by TC »
Make that two. Installed a 28' strip in the galley above the stove. Lit up both counter tops and the floor. Current draw is .04 amps. I first cut a strip of plexiglass slightly wider than and longer than the strip of LED's. This provided a clean smooth surface for the adhesive. I then screwed the plexi strip to the under side of the shelf above. The Admiral loves it. I got a bushel basket of Brownie Points for that one.
1989 F-32
Penetang,
Georgian Bay
2024 Gold Support
2024 Gold Support
I found a business right here in Dallas that specialized in LED. Wow my imagination just goes wild. I am sure most of you have a similar business in your towns. It boggles the imagination what can be done and not using much power. :D
Reel Easy
Post by Reel Easy »
Can you get a dimmer to work with LED?
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
bjanakos
Post by bjanakos »
I put LED under the galley cabinets and salon window sills. The dimmers work great.
2024 Gold Support
2024 Gold Support
my strip of leds has a remote control that you can dim, change colors in any configuration. Flash running light etc. Mostly will use for just lighting.
K4282
Post by K4282 »
I had the ebay strips on rolls, nice and bright, draw little power however the adhesive/mounting isnt great at all but hey their cheap made in china, you get what you pay for
Coonash
Post by Coonash »
I replaced mine with 4 led light strips.
1984 Trojan International 10 Meter
gettaway
Post by gettaway »
I bought the Ebay strip lights & dimmers and installed them as indirect lighting throughout the boat, we rarely use the overhead fixtures any longer as they produce a bright harsh light at night, the indirect lights give plenty of light and is much easier on the eye. Having dimmers helps tremendously in letting you adjust the light output to a pleasing color to you.
I think mine are all warm white, cool white looks more blue,
1984 Silverton 37C
Silver Lining
Scott
Reel Easy
Post by Reel Easy »
I like it. Do you have a link to the eBay site?
Dustin
gettaway
Post by gettaway »
This is the link to the eBay seller for the LED strip lights, you can choose many options, I went with the single color warm white, also, be sure to purchase the strip to strip connectors as it makes it very simple to cut the strip light strand and make the connections, the LED strip wiring is like a circuit board in that it has a thin copper strips embedded in the flexible coating, soldering the connections is difficult at best, you can do it, but be patient, or, buy the connectors( if you buy the double side connectors, you end up with double the number of strip connectors.
lights
http://www.ebay.com/itm/5M-300LEDs-SMD- ... 84e6326189
Connectors
http://www.ebay.com/itm/10x-8mm-3528-LE ... 3f29073a10
This is the type of dimmers I used,I have a separate dimmer on each strip, as each area I have set a different light level
http://www.ebay.com/itm/Brightness-Swit ... SwFL9TsmPK
1984 Silverton 37C
Silver Lining
Scott
gettaway
Post by gettaway »
By the way, there was previous post about the adhesive backing on these LED strip lights, while they say 3M, they don't adhere well, so I used an upholstery stapler and stainless staples which are just a slight bit wider than the LED strip, so I stapled them at every "cut here" mark for the length of the light strip, it hold perfectly and if you are careful, this doesn't damage the light strip in anyway
1984 Silverton 37C
Silver Lining
Scott
gettaway
Post by gettaway »
1984 Silverton 37C
Silver Lining
Scott
K4282
Post by K4282 »
Good tip on the staple to hold them in, assuming theirs wood at your mounting surface, i was thinking maybe a silicone 3m 4200 Maybe as well
