1984 Trojan 11M Express 32000
Posted: Tue Aug 21, 2012 1:56 pm
by BeaconMarineDon
1984 Hull
Crusader 350's +-1100 HRS
Onan 6.5 1000 HRS
New bimini/eisenglass/camper
full set of rear screens
full set of rear canvas
New 28oz carpet
New cushions (all of them)
New countertops
The hull has been pole sanded with 40 grit and 2 coats of Interlux ACT are on it, all zincs (mains also) have been replaced, all belts, all plugs, new wires on the Onan, all impellers, temp senders, wet exhaust and Tee on starboard main, starter on port main, all 3 bilge pumps to Rule1500, floats as well. Fuel tank and contents have been polished. I launched on 8/16/12. The list goes on and I have all receipts. A full survey in 2010 was used as a template for the update. It is sweet. It is in Rock Hall, MD 21661.
I have replaced many items over the past two years, for an 80's model, it is pristine and runs beautifully. Please call if you'd like to talk. I'm a motivated seller and promise not to waste your time.
Price: $25,000
James Wallace
jaahmez@hotmail.com
301 648 5510
Image[/url]
Posted: Sun Oct 07, 2012 10:10 am
by jaahmez@hotmail.com
Best offer before winter of 12 haul out and it's yours.
The A/C has taken a dump, it works but will not hold freon, pretty sure a line inside the R/W cooling has split.
James
Posted: Sun Nov 25, 2012 9:06 am
by Commissionpoint
Somebody should step up and buy her. I could easilly see Jeff & Amanda cruising around Va. Beach in her.
I like that Spec. J 6.5 Onan in there. That thing is a tank. I have a Spec. J as well, I've been running it alot this season. I had to crawl around it a bit when I got the boat in the spring and 'persuade' it a little (new fuel pump), but it just goes and goes. I've put my Westerbeke plans on hold for awhile because of it.
Posted: Sun Nov 25, 2012 1:37 pm
by k9th
Nice looking boat.
