Replacing salon glass
Captrichc
Post by Captrichc »
Does anyone have the templates for the sliding glass on a 32f sedan. 1 glass is cracked. And the rest are very hard if not impossible to slide.
1974 f32 Sedan
Twin 233 Mercruisers
Captrichc
Re: Replacing salon glass
Post by Captrichc »
Or does anyone know how to remove the sliding glass. I haven't seen and screws for the framing
1974 f32 Sedan
2024 Gold Support
2024 Gold Support
I believe you pull out the H channel and it comes out , But I know its been posted here a few times
Barrie
Post by Barrie »
If it's the same as my 1977 Tri Fly, slide the glass to one end and look up top. Inside the "F" track there will be small screws holding in the "F" track and the front angle that makes up the top frame. (the frame is essentially a channel holing in the windows but the top channel is actually made up of a couple angles....one you can remove.
The window and "F" track should just fall in once the screws are out.
Hope this helps
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
