How to remove a F-28 dinette table
gofish103
Post by gofish103 »
Ok heres another bonehead question. Is there a trick getting the table out of the brackets?? I've pulled and pulled. was on my back pushing up from underneath with my legs and this thing will not budge!!! I see no buttons or levers to push or pull!!! uugh!!
Tilt up and lift . brackets could be bent so some cussing may be needed
robertBrown3232
Post by robertBrown3232 »
I have to wiggle mine back and forth and it will slowly come out. Good luck. Stop my Herl's Harbor and I will show you.
I have a 28 ft Trojan docked on Catawba Island in Onio. Would like to hear from other Trojan owners in the area.
gofish103
Post by gofish103 »
I've wiggled it, Ive jarred it, i've pushed and pulled!
the boats still dry, but we have a place at catawba moorings.
ready123
Post by ready123 »
gofish103 wrote:I've wiggled it, Ive jarred it, i've pushed and pulled!
Hold it up about 30 degrees and have someone else tap it up next to the hinge while pulling away from the hinge. It should pop out... then maybe all you need to do is clean the hinge parts and add a little zip lube for next time.
gofish103
Post by gofish103 »
mine isnt hinged. it is self standing, it has two posts that support the table. the posts are approximately 3 or 4" in diameter
kevin babineau
Post by kevin babineau »
ive used a muffler bearing removal tool..lol those things can suck big time...im not suggesting this but what i have done is drill a hole thru the pipe and insert a big philips screwdriver and tap it around while soaking it with pb blaster
ready123
Post by ready123 »
gofish103 wrote:mine isnt hinged. it is self standing, it has two posts that support the table. the posts are approximately 3 or 4" in diameter
OK... twist them using an oil filter chain wrench to loosen the seize.... then you should be able to pull them out.
gjrylands
Post by gjrylands »
If all else fails, you should be able to remove the screws that hold the table to the posts. You can then work on the posts separately. You should be able to wiggle them out with a little penetrating oil.
Gerry
1979 F36 Twin Chryler 440's
gofish103
Post by gofish103 »
removing the bases from the table first was my next move. I'll shoot them with some spray lube and hope they work there way loose
NealW
Post by NealW »
I had trouble getting mine out too. I had to unscrew the base, soak it with penetrating oil and then used a block of wood and a hammer to get it apart. Good luck.
MDrywa
Post by MDrywa »
It sounds like the table has never been removed. I removed the table and bases on my '76 F28 and love the added room. We use a small fold up table that we use inside and out. The only down side is that you lose the extra sleeping area if you remove it from the boat. But it sounds like it was never used as the double bed anyway.
guglielmo6160
Post by guglielmo6160 »
explosives
1983 10 meter express
gofish103
Post by gofish103 »
our plan for the salon is to eventually remove the table and L shaped seating around the dinette. we want to put a pull out couch there. but were having problems finding the right size.
thats always the case too small or to big
