Thru-hull shaft leak 1971 F26
I have a small leak where the shaft goes thru the hull. I've tightened the fitting as much as I can with my hand. Is there a special tool used to tighten it? How else do you stop the leak? It's not much, maybe 1 drop every 3 seconds. Is there a proper name for that fitting?
Shaft Fitting
Must tighten properly ... need 2 pipe wrenches ...
see
http://www.alohaowners.com/pages/projec ... ng_box.htm
Do NOT remove the nuts Davey Jones!
see
Check out this link for an excellent set of instruction and really sharp pictures of how to repack the stuffing box
http://www.pbase.com/mainecruising/stuffing_box&page=1
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
