F32 Forward Hatch Latches
Good morning.
Does anyone know where to find the original forward hatch latches used on the F32 (1974 model in my case).
I have 2 that need replacing, but will replace all of them (6 total) when I find them.
The latches each mount to the Acrylic with 2 screws and hang down and snap into latches mounted on the hatch frame on the deck.
Thank you in advance for any help...
Re: F32 Forward Hatch Latches
Have your tried beacon ? also do you have photo ? may help ID what you need .
Will upload photo ... probably same as you have on your hatches Paul...
Swings loosely and catches in latch o with 2 "fingers", so it can be propped open a bit....
That sounds different then mine . But .... maybe not
Paul,
Found it ... https://www.trojanboats.net/zencart/ind ... 4dde32fe04
$65 each is a bit high ...
Would love to have stainless instead ...
A lot different than mine .
really? yours must have been replaced ...
Beacon says "Hatch lock used on all F-Series boats" on https://www.trojanboats.net/zencart/ind ... 4dde32fe04
What do you have?
What do you have?
I believe OEM belive I have seen them on other Trojans ( or not lol ) . If I remember I will take a photo
- ready123
Those are Perko latches, do an Internet search I've seen them for $47.
Those are not original my original had a chrome U section not plastic....... was not able to find them so replace one with the Perko.
Here is what mine looked like before I sold them.
Thanks Michael ... will look for them ...
