Page 2 of 3
Re: 84' Trojan F32, in too deep?
Posted: Thu Sep 16, 2021 6:42 am
by Moderator
Any pictures of the project?
Posted: Fri Sep 17, 2021 1:42 pm
by Velislide
I'll try and get some up.
Posted: Fri Sep 17, 2021 1:47 pm
by Velislide
Posted: Fri Sep 17, 2021 1:48 pm
by Velislide
- orig8.png (140.24 KiB) Viewed 7015 times
- orig9.png (152.46 KiB) Viewed 7015 times
- orig10.png (150.09 KiB) Viewed 7015 times
Posted: Fri Sep 17, 2021 1:51 pm
by Velislide
Posted: Fri Sep 17, 2021 1:58 pm
by Velislide
Of course had to start with some fun things, so got together what I wanted for the sound system, figured out the back deck placement, and got to work on that. Went with all Infinity, as it worked out great in my last boat. Finding space for the 10" subs proved to be a challenge, so had to make some boxes, and stuff them with polyfill to get the frequency down as low as I could. Been lazy, so haven't busted out the body filler on them yet. I did end up making them sealed boxes, adding on to the backs, as free air subs sound like absolute trash, otherwise.
- speakers1.png (146.8 KiB) Viewed 7015 times
- speakers2.png (146.9 KiB) Viewed 7015 times
- speakers3.png (145.13 KiB) Viewed 7015 times
- speakers4.png (154.37 KiB) Viewed 7015 times
- subbox1.png (149 KiB) Viewed 7015 times
- subbox2.png (166.27 KiB) Viewed 7015 times
- subbox3.png (159.48 KiB) Viewed 7015 times
Posted: Fri Sep 17, 2021 2:02 pm
by Velislide
Posted: Fri Sep 17, 2021 2:06 pm
by Velislide
Posted: Fri Sep 17, 2021 2:10 pm
by Velislide
Since I am trying to do this on the cheaper side of things, I scored a free new RV couch, take out from a new Keystone RV? I Think it was. They wanted bike racks, I wanted a couch, so it was a win-win. Slapped together a frame for this lightweight thing. Will get finished more later on. Also got the sump for the shower I need to install now, and then I can start working on the flooring for the kitchen/forward. Playing around with stains also, finally found a color I like. Going to be doing red mahogany wood stain, with white quartz countertops everywhere. Found a good deal on some quartz, hopefully it goes through.
Posted: Fri Sep 17, 2021 2:15 pm
by Velislide
Might be moving the couch to the other side, so I can put a TV stand on that side, and have an L shaped snack bar, coming off the kitchen divider. Basically will be my replacement dinette, as where the original dinette was, I'm going to be putting in 60" worth of cabinets, and moving the sink to that side. Fridge is going where the original oven was, so I'll be able to put in a much larger fridge. I guess if you can call 7cu ft a lot larger.
Posted: Fri Sep 17, 2021 2:26 pm
by Velislide
Now the hardest thing of this whole build, I have a feeling, is going to be finding a replacement flybridge acrylic windshield. That piece that wraps around the flybridge, to keep spray back I'm guessing. Mines cracked, and half of it is missing. No clue how I would get one made, or replaced. So if anyone has some solid leads or advice, I'm all ears.
Posted: Fri Sep 17, 2021 3:50 pm
by RWS
Looks like you are investing a lot of time and cash.
BEST OF LUCK WITH HER !
Posted: Fri Sep 17, 2021 4:02 pm
by rickalan35
Great pictorial report of your work! Coming along really nicely.
I was wondering if you'd found any delamination in your deck surface? Some of my friends have had that happen and have successfully performed their own repairs. Hopefully that problem is not present with your Trojan.
You could also paste your report onto the Trojan Boats Facebook page.
Rick
Posted: Fri Sep 17, 2021 4:24 pm
by Velislide
Mine has a few soft spots up on the forward deck. Inboard stringers also will need to be done, engine room back. Leaving that for last, lol. Was being used as-is, but everyone has their own standards. Anything can be fixed. In the end, still far cheaper then a new boat, and more fun when its something you've slapped together yourself. Traded a wheeler for the boat, and plan on having maybe 10k cash invested into it. Unless I decide to repower, which I'd be going diesel for sure. Some GM LM2 engines would be a nice fit. Originally thought about doing 6.0 gassers, for simplicity, but why not be different I suppose. Those new LM2's are light, make similar power and more torque than the crusaders, and sip the fuel. That can wait though.
First step, get the interior done. Second step, exterior and fixing soft spots. Third, well, pulling engines and all that fun.
Posted: Fri Sep 17, 2021 6:11 pm
She looks new compared to my F30 when I got her. ( it was bad) . Looks like your moving along and have a good handle on it. As far as diesel Yanmar has some nice compact ones. Would be easier to do than the LM2. With the LM2 it will take a lot of custom fabrication Mounts, heat exchanger water pump. exhaust manifold. bell housing, flywheel too.
