Posted: Tue May 12, 2009 7:49 pm
First, very handsome boat.
Rule makes bilge pumps up to 2000 gallons per hour or more that operate on 12 volts. Rule also make a float switch that either clips to the pump itself or can be mounted slightly aft of the pump.
The trick with these large capacity pumps is to size both the outlet hose and the through-hull at or greater than the diameter of the outlet flange on the pump. The large Rule pumps have, I believe, a 1-1/4" outlet so the hose and through-hull should be that size or greater to achieve the pump's maximum capacity. If you use smaller hose than the outlet, the pump's capacity drops dramatically.
Wire the pump directly to a battery (or battery bank) that you trust. Put the fuse as close to the battery as you can to protect not only the pump but the wiring to it. Don't pick up and use any old wiring. Run at least new #14 or #12 stranded copper marine cable directly to the pump, without splices.
The pumps come with pig-tail leads, which means making a connection to the wires to the battery within a foot or so of the pump. Make that connection well above the pump as possible and use butt-connectors fastened with a crimping tool. I like the butt connectors that can be shrink-sealed with a hair dryer or heat gun.
No twisted connections covered with electrical tape, ever. Those are a invitation to disaster for pumps or anything else on a boat.
