Fuel sending units
Posted: Fri Mar 04, 2022 6:16 pm
Another question for the forum guru's.....
Fuel sending units
Fellow boaters.... I have a 1975 Trojan FBMY with Chrysler 440's and I am getting very erratic fuel readings on the bridge. The fuel gauges are AC gauges and I have tested them by grounding out the sending unit terminal on the gauge and the gauge will read full, returns to empty when ground is removed. I have tested continuity and all pass the test. The 3 gauges(starboard, port and generator) all react the same. This leads me to believe that the erratic readings are due to failing or failed sending units. I have researched trying to find out what the ohm readings are for the sending units but have not found any results. Would any of you knowledgeable people here on the forum happen to know what the ohm readings are so I can test/replace the sending units? Two separate 180gallon main tanks and one 40gallon generator tank.
I have searched the forum and see many posts regarding the sending units however did not see anything regarding the ohm reading of the sending units. I think that I read someplace that the original main tank sending units were 30-120ohms. Can anyone confirm this?
Thank you in advance for any suggestions and help.
Fuel sending units
