When we got back from the canal trip I removed a home-built locker that had been installed across the length of the rear of the cockpit on our F-26. Yesterday I finally got around to checking under the small access panel over the rudder. I noticed that there was a small amount of water weeping up the rudder shaft and into the bilge. Not enough to be concerned about, but it did answer the question about where the water comes from when there is water pushing up against the transom while at the dock when there is a chop or swell. I've noticed water rising in the bilge of the cabin when we have this condition at dock (usually during a storm).
I tightened the packing and it seemed to reduce, but not stop, the water. I'm thinking that there should be NO water coming up the rudder shaft as it's not in need of water lubrication like the prop shaft. I then thought maybe the packing is stiff and needs to be replaced. I have no problem with the the prop stuffing box and packing - it drips the normal amount of 3-5 per minute.
Any advice?
Thanks!
Rudder Stuffing Box
Rudder Stuffing Box
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
