1988 10 Meter-mid cabin Rudder Bushings
Scott67
Post by Scott67 »
Just finished a small project and wanted to share my idea and results. Like a lot of these older girls, the original upper rudder bushings wear out and the tiller arms start to wear into the fiberglass rudder pockets. I ordered a couple replacement bearings from Bob at the Beacon, but due to the severe wear and the fact that I would have to probably "double-up" the bearings, I decided to come up with a similar repair plan that would give me piece of mind and some longevity. I decided to add a floating washer/bearing in between the tiller arm and the lower bearing flange just for added friction surface.
So, with the help of a local machinist friend and a stick of 6/6 Nylon, I went to work measuring and came up with the pictured before and after:
Rudder 1.jpg (77.89 KiB) Viewed 3880 times
Rudder 2.jpg (70.55 KiB) Viewed 3880 times
Rudder 3.jpg (68.61 KiB) Viewed 3880 times
Rudder 4.jpg (75.82 KiB) Viewed 3880 times
Rudder 5.jpg (77.28 KiB) Viewed 3880 times
"Speakeasy"
Model 340
Twin 454 (350hp) Crusaders
1.5:1 Gearboxes
Jacksonville, FL
2024 Gold Support
2024 Gold Support
Re: 1988 10 Meter-mid cabin Rudder Bushings
Nice work and good info.
