Generator Noise
Posted: Thu Feb 12, 2009 8:29 am
Hello fellow Trojan owners,
I'm planning ahead for a few spring projects, one of which is fabricating an enclosure for my generator. I'll explain what I plan on doing and hope to get some feedback from those of you who have enclosures as to whether my efforts will be worth it or not.
The boat is a '78 F-26 in which I rebuilt and installed a '70-'71 2.5kW Kohler marine generator a few years ago. As part of the installation, I added flame arrestors to the generator itself, the motor already has this, and updated the controls and exhaust system. This unit provides us with 120VAC @ 60Hz and enough amperage to run the AC, hot water tank, microwave, etc. My only complaint is the amount of noise. The exhaust isn't the problem, it consists of a Vernalift muffler and a Gensep water seperator. Most of the noise is from the motor itself.
Here's the plan. Using 1/8" 6061 aluminum sheet, I will build an enclosure with four sides and a lid. The front and right sides will be formed from one piece and will be held on to the left and rear sides with latches. The left and rear sides will be screwed to the stringers. The lid will be held on with lathces as well so thet the whole thing can be quickly opened up without tools. The bottom will be left open for ventilation. The right and left sides will have louvers stamped into them also for ventilation. All panels will be powdercoated and have sound insulation glued on the inside.
Well that pretty much covers it. Any suggestions that would help this idea work would be greatly appreciated.
Thanks,
Thanks,
