Gear Shifter, 1977 F-32
Tuck
Post by Tuck »
my starboard shifter has been really stiff since i bought this back in february. last night around 1am as i was backing into the dock, of all times, the bracket that holds the shifters in place broke and i had a hell of a time working the shifters in order to get docked.
the two parts which broke are just below the two upper screws, which allows the entire mechanism to move about, making it really hard to move the shifters.
i tried using some jb weld on the broken part today, and it's not going to work.
so, i need to find a replacement. does anyone have one laying around, or know where i can find one? will any type of shifter work (i.e. morse)?
thanks again in advance for the help.
I have one in good shape , I replaced both mine when one broke Let me know if you want it .
Mrsluggo
shifter
Post by Mrsluggo »
I am sure that becon marine has one of these shifters ,those guys got everything . If not I have a few in my shop you can contact me at mrsluggo121@aol.com and we can make arangments to get one to you by the weekend ;Jack
just for fun
davidsmith
shifter
Post by davidsmith »
Tshifter probably was not the problem just the weakest link. Stiff cables caused shifter to break.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
g36
shifter
Post by g36 »
tuck if its the same as when i was with you the corrosion in the cable at the upper station is causing the insert not to slide in and out of the sheath. the shifters should easily move from forward to reverse. if this is the cable i remember it may need to be replaced to the upper station, if it is you might be smart to replace both if they appear to be the same age since the you figure they have been exposed to the same elements over time. it seemed like the lower helm station worked fine when i isolated the upper station.but thats been a while back now.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
See if the cables are causing stress on the shifter pivots and levers. Once you find the cause, lubricate or repair. Then replace with the beefier Morse controls.
Tuck
Post by Tuck »
tks to the uber prowlerfishmeister, i have the part needed on the way via snail mail. kudos to you sir! you're on my Christmas card list, along with g3. :D
and yep, i'm having the shifter cables replaced as well. had a gentleman who's worked on the boat in the past come by to look at it yesterday...order the cables...and is going to fix me up.
once again, you'se guys come thru for a fellow trojan-holic. :lol:
