F-32 Shower Drain...This makes the 3rd Question
Posted: Tue Jul 14, 2009 12:30 pm
by Tuck
Sorry, I knew there was something else I needed an answer to...
My shower drain is draining painfully slow. The pump is running, but the drain appears to be clogged (I assume the pump is okay). My question is this: What can I use to unclog these pipes, if that's indeed the problem? I've not used the normal methods, i.e. Liquid Plumber, etc, because I'm not sure if the pipes, which I assume are original, could handle it.
Advice, please.
Thanks again.
Posted: Tue Jul 14, 2009 12:36 pm
by LSP
Have Glenda bring by one of her snakes....
Posted: Tue Jul 14, 2009 12:38 pm
by Tuck
LSP wrote:Have Glenda bring by one of her snakes....
lol
Ya know. I feel just about retarded. I dunno why I didn't think of a snake before making the post.
Guess that's what I get for trying to sneak a net-run while in the office.
Tks. A snake it shall be. Although, I don't think Glenda's has them. lol
Posted: Tue Jul 14, 2009 1:02 pm
My f 36 has a screen between filter ( screen ) and the pump near the pump . you may want to check that .
Posted: Tue Jul 14, 2009 1:33 pm
by JuiceClark
prowlersfish wrote:My f 36 has a screen between filter ( screen ) and the pump near the pump . you may want to check that .
mine was draining slow once and I checked that little screen at the pump. It was packed full of sawdust from when I sanded the cabinet and <somebody's> nasty pubes. GROSS
Posted: Tue Jul 14, 2009 2:05 pm
by Tuck
tks for the replies. i didn't know this, and will check this afternoon when i get to the boat.
hope it's that simple.
Posted: Tue Jul 14, 2009 5:09 pm
by Tuck
tks guys! once again, you guys come thru!
i found the pump, and sure enough, found a small filter in the line. took it out, and the screen inside was covered with gunk thicker than michael jackson's media coverage.
took it outside, took it apart, cleaned it, stuck it back in, and wala! drain works better than it has since i've had the boat.
now, on to the next issue i can hopefully tackle myself...the placement of the transducer.
tks again guys!
Posted: Fri Jul 24, 2009 8:01 am
by jwrape
For Future reference I have plunged mine before and loosened up the junk in it to get it flowing again.
But then again, my shower pump hasn't worked in a couple seasons. The Belge has been taking care of the job. I have a new pump but just haven't gotten around to replacing it yet.
