long shot... anyone know of a mid cabin parts boat?
Posted: Tue Jan 26, 2010 1:50 pm
by BobCT
My bow railing is bent on the starboard side along with two of the stanchion supports. I could probably replace those but not sure what my options are for the railing itself.
If I could get another one reasonable priced I would do that since I need to re-bed everything anyway.
Re: long shot... anyone know of a mid cabin parts boat?
Posted: Tue Jan 26, 2010 2:45 pm
by Rodman
BobCT wrote:My bow railing is bent on the starboard side along with two of the stanchion supports. I could probably replace those but not sure what my options are for the railing itself.
Railing is quite easy to come buy. Just (Google) it. Hold on Ill do it for you.
http://www.defender.com/category.jsp?pa ... &id=309310
http://www.defender.com/category.jsp?pa ... &id=311487
Posted: Tue Jan 26, 2010 3:03 pm
by Stripermann2
Better yet, why not call Bob for your Trojan parts...I'm sure he can find what you need at a reasonable price. And, you'd be supporting a good cause.
Contact Bob at Beacon Marine Supply -- (609)713-4602
Posted: Tue Jan 26, 2010 3:05 pm
by Rodman
Stripermann2 wrote:Better yet, why not call Bob for your Trojan parts...I'm sure he can find what you need at a reasonable price. And, you'd be supporting a good cause.
This is true also.
Posted: Tue Jan 26, 2010 3:56 pm
by MTP
if bob cant help you, you could contact Capt Ross he offered to do some work for largo
I didn't explain it very well....
Posted: Tue Jan 26, 2010 3:59 pm
by BobCT
yes, I'm happy to contact Bob, have bought stuff from Beacon before.
BUT, the reason I asked about a parts boat (in addition to some odds/ends) is that the horizontal bow railing is bent inward. Previous owner hit something.
So, I either need to replace it with another one or try and get it repaired/ straightened. It look like one piece and has the curve going up to the bow.
Maybe not, I haven't actually taken one of these apart before.
Posted: Tue Jan 26, 2010 4:23 pm
by ready123
The railing should have small screws underneath where the sections are joined over an inner sleeve. The joint seams often are not clearly visible from the top.
Posted: Tue Jan 26, 2010 4:24 pm
by alexander38
sounds like something that will have to be made, start at your marina and see if there's anyone that does custom S/S work. most likely they'll have to use the other side to match it up.
