1987 10 Meter Int -Express 330 cutlass bearing sizes??
Posted: Fri Mar 05, 2010 9:02 pm
I was wondering if anyone has the O.D. for the cutless bearings on the 1987 330 Express?? It has 454 Crusaders with a 1 1/4 shaft- I have two struts per drive shaft for a total of 4 struts that need cutless bearings. The forward cutless bearing is 2" long and the rearward cutlass bearing is 5" long. The I.D (shaft size) is 1 1/4.
My measurements of the O.D. of the cutless bearing in the rear don't seem to fit the standard sizes avaliable. I must be off a little.
The forward cutless bearings are 2" long and I don't see much offered for that size at all with a 1 1/4 shaft (I.D.)
I need the size of the cutless bearing to get the correct size parts for the puller, otherwise I would just wait til I popped one out and could get a better measure of it or just bring the whole thing in to the store.
Thanks!!!
Thanks!!!
