Pulled the fuel tanks out today.
Sea Ya
Post by Sea Ya »
Pulled em. Redoing floor so no problem there. These are the original 1971 tanks. Outsides are nice insides have a bit of rustI need to get them cleaned out somewhere. Not sure where in Tampa Florida area. Here are some pics, O look at the first one. The builders put a loop of Nylon rope in. Around the stringer. Maybe to lower or for good luck? Only on port side.
72 Cutlass Jet 460 Ford (LIKWIDSUKR)
71 TroJan F26 300Hp 351Windsor ( SEA YA )
JuiceClark
heavy
Post by JuiceClark »
I remember those two tanks under the cockpit like it was yesterday. They were SO heavy...almost killed 4 of us. Actually, the saddle tanks in the engine compartment almost killed us...these small ones just gave us all hernias.
I had a local welder make a single, aluminum tank to replace all four tanks that were in my F-36. The boat floated like an inch higher after that project...bet we lost 1000 pounds. Replacing the 440s with 454s prolly' lost and 600 pounds and throwing the old Onan generator away and it's little tanks had to be at least another 1000 pounds. Boat got so light I thought it may start to levitate.
Tony in Fort Myers
Sea Ya
Re: heavy
Post by Sea Ya »
JuiceClark wrote:I remember those two tanks under the cockpit like it was yesterday. They were SO heavy...almost killed 4 of us. Actually, the saddle tanks in the engine compartment almost killed us...these small ones just gave us all hernias.
Tony in Fort Myers
No doubt they were heavy. I pulled them out by myself up and out then off the boat alone both of them.
JuiceClark
pictures
While you're at it, I'd really like to see a pic of that jet-boat too. I'm down here right at the mouth of the river in Ft Myers. If I take a left I'm out in the gulf. If I take a right, I can take the river all the way to Palm Beach...was thinkin' about using all these old 454 parts to make a jet boat.
Thanks, Tony
chumwithabottleofrum
Post by chumwithabottleofrum »
I pulled my fuel tank two years ago, had it cleaned pressure tested and coated. If you are looking for a shop that does this type of work-look for shops in your area that recondition radiators-generally they also do gas tanks.
Sea Ya
Post by Sea Ya »
chumwithabottleofrum wrote:I pulled my fuel tank two years ago, had it cleaned pressure tested and coated. If you are looking for a shop that does this type of work-look for shops in your area that recondition radiators-generally they also do gas tanks.
Do you remember a round about cost for this?
I'm having trouble remembering, but I want to say around $185-it was considerably less than a new tank.
Sea Ya
Post by Sea Ya »
chumwithabottleofrum wrote:I'm having trouble remembering, but I want to say around $185-it was considerably less than a new tank.
Gotcha seems right. I might do it myself. Either citric acid or muritic acid then coat with kreem or red coat.
2024 Gold Support
2024 Gold Support
Replace the tanks coatings may not hold up . worked so so before and with the new fuel , who knows, I have read smoe bad reports I would not do it .
Sea Ya
Post by Sea Ya »
prowlersfish wrote:Replace the tanks coatings may not hold up . worked so so before and with the new fuel , who knows, I have read smoe bad reports I would not do it .
Thanks for the feed back for sure.
etpence
Post by etpence »
those are the org galvanized tanks is your in salt water change um for alum. I just changed both for 900.00 they were 80gal apeice
mine looked good on the outside but after internal inspection found bad pitting on the inside
if your pulling them out your better off upgrading for less future problems
Todd 30' trojan MioMio
rossjo
SS!
Post by rossjo »
Stainless tanks are nice! I have 1 on my Stbd side. No corrosion and looks great!
Sea Ya
Re: SS!
Post by Sea Ya »
rossjo wrote:Stainless tanks are nice! I have 1 on my Stbd side. No corrosion and looks great!
Im sure they are for a price :)
rossjo
But
Post by rossjo »
But .. if you plan to keep your boat a few years - and make long trips (as in 50-75 mile offshore), the Stainless pays for itself in longevity and peace of mind.
