Installing a new floor
We live aboard our F40 aft cabin and our carpet is past its retirement age. She wants something like a hardwood flooring, or like teak and holly, has anyone replace their carpeting, what did you use, thank you
Was just at the boat show and saw a lot of people looking at that new material that looks and feels like teak and or other wood, but it's actually an easy install material like laminate, not sure what it really is cause I wasn't interested but later on in the day I saw samples at west marine, it's thicker than laminate flooring but looks simple and really does look and feelnlike teak wood.mi saw a few new boats with it today to, saw one swim deck that looked like real wood but it was this material. Unweatherable, easy wash down... Kinda neat the closer I looked. Beats having to lay a reall wood floor. Just thought I'd tell ya what I came across today since I just so happen to hit the mid-Atlantic boat show then go shopping
That's my cabin. Under the dinette the 1/4" Teak & Holy plywood is glued down to the existing floor. In the walkway, its glued down to a single piece of 3/4" marine ply. Then the whole thing is screwed in around the outside edges. The screws are then hidden with 3/4" round moldings. This way I can still remove it to access the bilge.
The glue I believe was PL2000 from HD. Clamped it all down tight during the curing process.
chas1450, you are likely referring to NUTEAK or PLASTEAK. Both of these products are available in interior and exterior material. It is NOT an easy do it yourself project, in my opinion. Each piece is cut and clued with a special technique for the border. The cost to.do my F36 tri cabin throughout is around 8K. It is nice stuff though. Several boat manufactures are using it. jimbo36
from what i saw today, because now we are aruguing over keeping the teak look vrs the grey and white an black. lol/ thanks for the pics btw... it is beutiful no doubt... i would deff glue. im thinking of doing a water fill test to see if the bildge pump can be moved up 2 feet and still be safe. im in a position to do this so... acuaully since im moving the bilge pump up 2 feet for a test and its the free pump i got with the boat, im going to modify the screen to fit flush with the haul. we will see if i can move access panel to under the bunk and put a primary further back that can be trusted and sealed like yours. so just incase i wont have to pull trim to get main pump. am i making sence? 2 pumps 2 feet from each other, just for easy service if need be?
- ready123
2 pumps one in bow and one in stern.
When underway the bow pump will do nothing and opposite when docked.
- Muskokan345
Jeff, Paul has done it right, by gluing the teak and holley to the plywood and screwing it to the cabin sole, it can be removed for inspection, any surveyor worth his salt is going to want to see the ENTIRE bilge area, keep that in mind. It's not as big a deal on our "little" boats, but, any knowledgable buyer would want to see under the cabin sole, I know I would!
1986 F26
