NEED HLP ASAP PLZ ON PROP
Sea Ya
Post by Sea Ya »
Ok i have a paragon vdrive a 351 and a 71 trojan f26. i have on the boat now a 15 x 8 LHD prop. I also have a 14 x 10 RHD prop. Can I switch props and use reverse as forward? The shaft comes out in middle of boat.
Maybe stupid question but i need a prop with more pitch/bite.
72 Cutlass Jet 460 Ford (LIKWIDSUKR)
71 TroJan F26 300Hp 351Windsor ( SEA YA )
rossjo
NO
Post by rossjo »
Are you serious? Do you even have separate throttle and shifter?
I don't think this is a good idea - even with tseparate throttle/shifter. - would you turn the shifter around or what? Are the reverse gears the same ratio?
Mac32
Post by Mac32 »
Some of the V-Drives have different ratios for forward and reverse (I know at least Borg Warner does), so check the model plate....., and you may want to check with the manufacturer (or support center)directly with your model handy and see what they say.
My gut says make sure you are not saving a penny today to spend a buck later. Been there done that.
Fred
rossjo
Shaft Size?
Post by rossjo »
What size shaft? Are you sure is LH? Seem odd ... std is RH ...
eBay ... 14 & !5 inch Brass/Bronze/Nibral Props ... :shock:
http://search.ebay.com/search/search.dl ... age=search
