Repowering F26
Repowering F26
I am looking into putting in a brand new sportac 5.7 mfi engine with a 2 year warranty. Boat is in great shape so my thinking is in the long run this would be my best choice. Had a chrysler 360 reman and the main bearing took a crap.... I dont think i want to go that route again so asking on here i figured i get some good feed back on this .. Thx in advance
Classic 1977 F26 HT 5.7 MPFI 350 (330HP)
CLAS-SEA
Carl
CLAS-SEA
Carl
- The Dog House
The 5.7 mfi is a good engine. My previous boat had a Volvo Penta 5.7 GSi which I was very happy with. Others in the forum have said that the Vortec 5.7 engines are too tall to fit in the F26. Be sure to check the height of the engine to ensure that it will fit. You might have to take off the plastic air intake cover. Also, what horsepower is the 5.7 mfi? You will need a new bell housing to mate the 5.7 mfi to the current transmission, so if the horsepower is significantly more than the 360 you might want to include a new transmission as well.
Former boat: 1971 Trojan F26
the chrysler 360 had 260 hp, the sportpac 5.7 has 300 hp. Both Jerrys Marine in Fort Lauderdale and my mechanic say the zf 450 tranny can handle the extra HP. This engine comes with bell housing etc etc. Just trying to weigh the options before i buy. Im a little leary about another reman. Wifes eyes began rolling when i first brought it up but that was to be expected. The cost is a bit higher but peace of mind can be priceless as they say, not to mention safety.. Sooo im building a doghouse just in case .. Thx for any input or expertise
CLAS-SEA
Carl
CLAS-SEA
Carl
I have a Crusader Captains Choice 5.7 vortec motor rated at 330hp with a Borg Warner Velvet Drive, it does fit but it's pretty close, . I did have to remove the black cover though.
I did replace my cockpit deck awhile back, it's pretty close to the original height though it might be different than yours . Also, there is now a 6.2L engine which is not as tall as the 5.7
When I went through this, on Crusader's web site they had some documentation on how to measure, and included diagrams. It was very helpful. With the decorative black cover it wouldn't clear, but once it was removed it fit OK, I have 1/2 inch from the highest point of the flame arrestor. It was the best thing I ever did and would do it again
good luck
good luck
- The Dog House
The Crusader 6.0L is 4 inches shorter than the 5.7L.
http://www.crusaderengines.com/NewFiles/60specs.pdf
http://www.crusaderengines.com/NewFiles/5057specs.pdf
It also produces 375 hp, which may be too much for the F26. I'm not sure how much is too much.
Of what ive read on here and talked to a few mechanics , 375 hp would be overkill for the F26. And as other Trojan owners have said these vessels are for cruising not speeding so i take heed with those statements. Man, after researching engine prices looks like ill be cutting some expenses in the future.
CLAS-SEA
Carl
CLAS-SEA
Carl
Yeah, ive reconciled that it is all worth it tho, nothing better then being on the water for me. My grandfather was in the navy, my dad was in the navy and hearing their stories being out in the pacific and atlantic gave me the bug at a very young age. Ill pay for that kinda life and be happy to work harder to afford it . Ahhh for all the stories we will be able to relate !!!
CLAS-SEA
Carl
CLAS-SEA
Carl
375hp is alot for an F-26 and especially a 1"shaft. Mine has 330hp compared to the original Chrysler 318 which was rated at 225hp. Regarding the swap to a brand new setup, it can get quite expensive. I'm amazed at how much the 5.7 Captains Choice has gone up in price over the last 9 years since I did mine. A lot of it depends on how long you plan to keep the boat, and what you want to do with it. You will definitely have to set aside some extra money for hidden expenses that will pop up.carlywolf wrote:Of what ive read on here and talked to a few mechanics , 375 hp would be overkill for the F26. And as other Trojan owners have said these vessels are for cruising not speeding so i take heed with those statements. Man, after researching engine prices looks like ill be cutting some expenses in the future.
As far as performance, I am running the same pitch prop as I was with the 318 which is a 14x10" cupped prop . The Chrysler was rated at 225hp at 4000 rpm, while the new 5.7 is rated at 330hp at 5000 rpm. The recommended rpm band for the 5.7 is 4800-5200rpm at WOT, currently I achieve 5100 with full fuel. Cruising speed has not really changed that much, 3000rpm with a 1:1 transmission is 3000 rpm, whatever the HP is. The boat gets on plane quickly and does burn less fuel. Top speed is just under 32kts, but I only achieved this once while I was making sure I could reach the recommended rpm, the boat wasn't designed to run at that speed and I wouldn't recommend it. It will cruise all day comfortably at 15-17kts and is very fuel efficient. The best part is having the extra power when needed, especially in a following sea. I couldn't believe how this engine transformed the boat. I know I'll never get my money back on it, but it's been well worth it to me, providing me a "new" boat at a fraction of the cost. It has given me plenty of good use over the last 9 seasons.
