1972 F-26 Cutlass Bearing Size?
Posted: Fri Oct 19, 2007 1:57 pm
Well I'm gonna haul the boat soon to replace the prop, zincs and such. I figured it's probably time to replace the cutlass bearing (have a vibration) but I don't know the exact size I need. I know the shaft is 1" diameter but I'm not sure of the length or outside diameter of the bearing. I'm guessing that it's a 1" inside dia. X 1 1/4" ouside dia. X 4" long but I can't verify that until I'm out of the water. I'd like to order the bearing before I haul the boat so I can spend less time on the hard. Does any one know the exact size of these things for this particular boat?
This is where I plan on ordering the bearing:
http://www.deepblueyachtsupply.com/series.aspx?id=2
Thanks,
Ken
1972 Trojan F-26 Hardtop Express
Chrysler 318 FWC
Paragon V-Drive Trans
Norfolk, VA
http://www.putfile.com/vabeach1234/images/98775
Thanks,
Ken
Chrysler 318 FWC
Norfolk, VA
