Bertram 10 Meter Sedan
BeaconMarineDon
Beacon Don
Beacon Don
Post by BeaconMarineDon » Mon Nov 25, 2013 12:18 pm
Up for auction is a Trojan by Bertram 10 meter (33 Feet) custom open sedan that has been in my family for the past 13 years. I have put many hours of work into this boat and it shows. This is the best deal you will find on a practical modern diesel boat, this boat must be sold and is ready to go today. For more information call me at 954-4671770. Its Delta conic hull makes for a fast 30kt dry and solf ride. The boat underwent an $150K re-fit in 2006 including:
• New electrical system, AC/DC with new custom fiber optic back lit
• Cummins engines 6BTA-5.9 370 HP 350 hours
• New flybridge dash and gauges, all new wiring.
• Monel shafts with new cutlass bearings
• PSS (packless sealing system) shaft seal
• Steering new rudders ram and hoses
• High performance propellers
• Water intakes bronze with free flow ball valves
• Strainers Perko 2" engines and groco 3/4 air and generator
• Water maker
• 16000 BTU super high efficiency air conditioning heat (digital)
• Westerbeke generator with sound shield 5 kw
• Bow thruster side power ST50
• 2500W inverter charger with remote
• Garmin GPS touch with sounder
• LED lights, inside outside
• Lofrans 1000 windlass
• Search light
• Custom top and cockpit shade
• New windows with green glass
• Fusion 700 stereo with Bluetooth
• Electric dining table inside cabin that converts into a bed.
• 3 Isotherm refrigerators /freezers12v cockpit
• 1 refrigerator in the cabin
• Microwave oven
• Stove
• Vacuflush toilet system
• Custom interior
• Composite water tank
• New Benett trim tabs
• New fuel tanks. 1/4 aluminum with new vertical sending units.
• New fuel polishing system
• Hydraulic engine hatch for easy access and service.
• Morse electronic engine controls. These are reliable and easy to operate.
• Flat TV with DVD
• Davit and dingy not included
• This boat was refitted by a marine engineer. It was done the right way!
Year: 1982
Use: Salt Water
Make: Trojan Bertram
Engine Type: Inboard
Model: 10 meter sedan
Engine Make: Cummins
Type: Flybridge
Engine Model: 6bta 5.9
Length (feet): 36
Primary Fuel Type: Diesel
Beam (feet): 13.6
Hull Material: Composite
Please message me for more information. Located in Fort Lauderdale, Florida.
Asking Price: $50k
Contact Information:
alain@mabrumarine.com
Alain Mabru
Mabru Power Systems at Lauderdale Marine Center
2015 SW 20th street #106K FT Lauderdale FL 33315
(954)5201015 cell
(954) 4671770
(954) 4671730 Fax
