Trojan F32
BeaconMarineDon
Beacon Don
Beacon Don
Trojan F32
Post by BeaconMarineDon »
Boat Name ==> JOUJOU
Overall Specifications
Dimensions
LOA: 33 ft 0 in
Beam: 13 ft 0 in
Maximum Draft: 2 ft 0 in
Bridge Clearance: 12 ft 2 in
Deadrise: 9 ° at Transom
Dry Weight: 14250 lbs
Engines 1, 2:
Engine Brand: Cummins
Engine Model: 6BTA 5.9
Engine Type: Inboard
Engine/Fuel Type: Diesel
Engine Hours: 350
Drive Type: Direct Drive
Engine(s) Total Power: 370 HP
Tanks
Fresh Water Tanks: (55 Gallons) // Fuel Tanks: (250 Gallons) // Holding Tanks: (40 Gallons)
Accommodations
Number of single berths: 1 // Double berths: 1 // Cabins: 1 // Heads: 1
Outside Equipment/Extras
Electric windlass
New items and extras installed in 2006
• New electrical system, AC/DC with new custom fiber optic back lit
• New Cummins engines 6BTA-5.9 370 HP 350 hours
• New flybridge dash and gauges, all new wiring.
• Monel shafts with new cutlass bearings
• PSS (packless sealing system) shaft seal
• Steering new rudders ram and hoses
• High performance propellers
• Water intakes bronze with free flow ball valves
• Strainers Perko 2" engines and groco 3/4 air and generator
• Water maker
• 16000 BTU super high efficiency air conditioning heat (digital)
• Westerbeke generator with sound shield 5 kw
• Bow thruster side power ST50
• 2500W inverter charger with remote
• Garmin GPS touch with sounder
• LED lights, inside outside
• Lofrans 1000 windlass
• Search light
• Custom top and cockpit shade
• New windows with green glass
• Fusion 700 stereo with Bluetooth
• Electric dining table inside cabin that converts into a bed.
• 3 Isotherm refrigerators /freezers12v cockpit
• 1 refrigerator in the cabin
• Microwave oven
• Stove
• Vacuflush toilet system
• Custom interior
• Composite water tank
• New Benett trim tabs
• New fuel tanks. 1/4 aluminum with new vertical sending units.
• New fuel polishing system
• Hydraulic engine hatch for easy access and service.
• Morse electronic engine controls. These are reliable and easy to operate.
• Flat TV with DVD
• Davit and dingy not included
• This boat was refitted by a marine engineer. It was done the right way
Contact Information:
email: info@ngyachting.com
Nicolas Guitard
Asking Price: $75,000
Click here for additional photos ...
