water leaks salon roof
how does the salon roof come off fly bridge and consol are off
salon roof removal 1978 F 32
help , remove roof on m yF32 1978
sorry for not being clear. I was talking about the shell above the salon ceiling . the outter shell that the consol and the wraparound screw onto. I think that I have to remove the rain gutter in 4 sections to do this . does this sound correct??????????? thanks for any help that you can render!!!!!!! mrsluggo sunoco sinclair b/p arco conoco hess dont import middeleastern or s/a oil
The rain gutters don't have to be removed.
To remove the surround, unscrew the 3 panels on the inside of the surround and remove. Also disconnect any wiring to lights, etc. Then you simply walk around the exterior of the bridge, removing the screws that hold down the surround. You will also need to remove or un-attach, the rear stainless railing from the side railings and ladder where they attach to the surround, you can also remove the ladder altogether and leave the stancions in the cockpit sole. You do not have to remove the stainless railing from the tops of the surround, the railings will slide out of the T-couplers.
Two - three people can easily remove from boat as I did. Hope this helps, good luck.
