I found a new way to winterize my A/C system. Maybe most people already do this but I just figured it out.
As I was winterizing the fresh water system I hooked a hose to the cockpit faucet. I then used the hose nozzle to push the antifreeze in thru the A/C discharge using the pump on the boat until antifreeze came out thru the intake. I did empty out the sea strainer before I started to make sure I ended up with antifreeze throughout the system.
Winterizing A/C
