Haven't been on the forum (or the boat) in some time due to my wife's health issues.
Our F32 is now back in the water after 6 months on the hill and then back up/down for hurricane Matthew. Its got a new bottom (literally - had to grind off everything including gel coat due to dishonest diver who didn't actually clean anything for a year). New bottom epoxy, barrier coats and 3 coats bottom paint, new Awlgrip transom paint, new water intakes for engines, new strainers, removed several transducers/thru-hulls and found a poorly patched hole in the bottom (which is now stronger than the hull), so we're solid now. Slowly sanding and repainting topsides (2 coats 2-party epoxy and 3 coats 2-part Awlgrip). Haven't been able to use this boat in a couple of years either, but plan to cruise some this fall/winter.
We don't like the console used on our 70's model F32 upper helm. Its low, has a silly backwards seat on the starboard side and has no place to mount electronics, etc.
We would like to upgrade
So a couple of questions:
1) Will the 80's style console work?
2) Does anyone know where I can find one?
3) Is the F36 upper helm console the same as the F32?
Thank you in advance, and looking forward to getting back in touch!
