power supply
power supply
i show this on my power supply....red light on the left with reading pegged to the right...on right gauge shows working...i unplug shore power and red light goes off..but gauges stay the same...could i have a polarity problem?
1979 321 Trojan
Re: power supply
i asume shore power ? Are you using bothe cables ? Check the voltage to make sure you not getting 220 on one side and check the polarity .
Re: power supply
using both cables and all outlets are on and working..headers, hot water,etc no sign of 220
1979 321 Trojan
Re: power supply
Did you check with a volt meter on the boat and on the dock ? That should be the first thing . You can get a polarity test at a hardware store and check polarity of the outlets . Have you tried swaping the cords at the dock ? Does the issue change sides ?
Re: power supply
heres a cube style polarity tester
Should be 1 on every boat
cost $10
https://www.amazon.com/Receptacle-Teste ... NrPXRydWU=
cost $10
Re: power supply
Exactly !RWS wrote: ↑Wed Mar 17, 2021 6:41 am heres a cube style polarity tester
cost $10
- P-Dogg
Re: power supply
I'll see your polarity tester and raise you a volt meter. Also serves to trip GFCIs, if you're into that kind of thing....
https://smile.amazon.com/gp/product/B08 ... UTF8&psc=1
Re: power supply
At minimum you need new gauges.
Re: power supply
Do you have the cross tie switch and if so is it in the right position for both cables connected ?
Re: power supply
There was an option that allowed you to power up both sides of the panel when only one shore power cord was connected. The breaker /switch was one of those lower ones on your 120 panel.The switch had to be in the correct orientation when both cords were used. Just a thought as it used to throw me if I wasn't watching. As I remember those polarity indicators were a bit on and off on our boat and I replaced the volt meters a few times.
