This is true. But what could be the other ingredients besides water? Wouldn't the acid destroy most other addictives?WayWeGo wrote: ↑Wed Aug 22, 2018 9:05 am Yes, that is the problem. Like most companies, they do not want to give away any of their secrets, so the technical data is vague and the MSDS only has to list dangerous chemicals. With the concentrate version being less than 50% phosphoric acid, there is another 50% of unlisted ingredients that are not hazardous, but not likely to be all water.
Barnacle Buster
Re: Barnacle Buster
1974 f32 Sedan
Twin 233 Mercruisers
- WayWeGo
Re: Barnacle Buster
I suspect the other ingredients include buffers to control the PH at safe levels and corrosion inhibitors.
If you have any aluminum or zinc in your circulation path for the flush, I would be very careful.
Re: Barnacle Buster
I dont know if I do. I was only going to run it through the heat exchange.
1974 f32 Sedan
- WayWeGo
Re: Barnacle Buster
You most likely have a zinc in your heat exchanger, not sure about anything else.
I only ran through my heat exchanger as only the elbows get raw water besides that. I did run the solution through my A/C afterwards.
Re: Barnacle Buster
BOTH are good Both will clean out scale and growth and will do a great job on the cooler
i like site athletesphysiques.com
Re: Barnacle Buster
I believe I only payed $60.00 for a gallon at West Marine. That was plenty to do 1 motor. I believe if you strain the used BB it can be re-used for the other motor. I have seen this but have not personally tried it.
- WayWeGo
Re: Barnacle Buster
One gallon of concentrate did both engines and my A/C raw water system.
Re: Barnacle Buster
I only need to do 1 engine since the heat exchange was just replaced on the other engine. And I dont have a AC unit... yet...
1974 f32 Sedan
