F32 Stringers Replacement
Martino
Post by Martino »
Built an A Frame to pull the motors. Then some bulkhead and stringer repairs and a fresh coat of Bilge paint. More pics to come.
oil&water
Re: F32 360 Motors coming out and Bilge Rejuvenation
Post by oil&water »
Did you run into any issues lifting them out with the A-frame? Any notes on position or additional support underneath?
Currently Trojan-less :?
One word: Ugh!
Mack wrote: Wed Jun 17, 2020 9:01 pm Well I'm replacing all the stringers! Talk about soft wet mush !
Lot of work . are you and Martino the same ?
buffalobill
2025 Forum Support
2025 Forum Support
Post by buffalobill »
Wow, that looks bad. Could you post pics during replacement? Would you consider steel fabrication along with the new wood? What bilge paint do you use? Thanks.
Martino
Post by Martino »
Well during the summer I made new stringers.
Created templates out of foam insulation board and then transferred them to 3/4 inch Marine ply.
I bonded 4 layers of ply to create 3 inch wide stringers. Bonded the stringers in the hull and then will encapsulate them in fiberglass.
Martino
Post by Martino »
More pics of the bonded stringers
Martino
Post by Martino »
buffalobill wrote: Thu Aug 13, 2020 9:39 am Wow, that looks bad. Could you post pics during replacement? Would you consider steel fabrication along with the new wood? What bilge paint do you use? Thanks.
I wouldn't use steel as a replacement. I think it would be to heavy.
dab62
Re: F32 Stringers and Motors Replacement
Post by dab62 »
You sir, are a better man than I. :) That is an impressive amount of work! Best of luck!
1987 F32
All Wrapt Up
Kent Narrows,Md.
Martino
Post by Martino »
dab62 wrote: Mon Oct 19, 2020 1:04 pm You sir, are a better man than I. :) That is an impressive amount of work! Best of luck!
Thanks for the compliment ! I have a ways to go yet but I will be so glad when the stringer a nd bulkhead replacement will be done !!
That is some nice work !
Martino
Post by Martino »
prowlersfish wrote: Mon Oct 19, 2020 5:43 pm That is some nice work !
Thank You ! I'll admit it isn't easy !! Very Labor Intense !
Martino
Post by Martino »
Bonded another stringer down last night ! One more piece to go tonight then the encapsulation starts.
Re: F32 Stringers Replacement
Very nice -- thanks for documenting here so others can see how to do it!
Martino
Post by Martino »
WayWeGo wrote: Wed Oct 21, 2020 1:50 pm Very nice -- thanks for documenting here so others can see how to do it!
Thank You ! I will post more in progress pics as I go along.
