Two Heads Better Than One?
A friend of mine had one head removed from his 454 Crusader because of a coolant leak, and they found that it was slightly warped so they milled it. They told him that it was a minimal amount removed and will be reinstalling it soon.
I assume that this will now increase compression slightly on that bank. Shouldn’t he have the other head milled as well to balance out the engine?
Torcan
Post by Torcan »
And here I thought you were talking about the crapper
http://www.cbyc.ca/
Hey, when you have kids on board, two heads (crappers) are always better than one!
Post by Paul »
Big D,
Definitely have your friend check the other head and at least change both gaskets. Usually if one head/gasket is leaking, the other is not to far behind.
It would be a shame to have to tear it down again to do the other head a year later.
rbcool
Post by rbcool »
DEFINATELY have both heads done!!!
And yes, 2 heads are better than one!!! I'll never go back to a single head.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
I would be more worried about the other gasket failing then the slight difference in compression . with that said I have done one head many times and not touched the other and never had a problem .Now if the engine overheated badly I would recommend pulling the other head . I would Not let a machine shop check the head for being warp be cuze the will mill it 100% of the time because its warped ( so they say) check it your self and check the specs in the book as some warping is allowed .
baring over heating he should be fine
on diesels its not uncomon to replace 1 cly kit and leave the rest alone or ove haul one side of a engine , with out issues . I know this a gas engine but the idea is the same .
alexander38
Post by alexander38 »
I'd pull the other just cause he's all ready paid to have the engine tore down ,do both sides.
rossjo
Post by rossjo »
I agree - not necessary, but its obviously an older engine, so as long as you've got it apart, do the other head and a valve job at the same time.
He's trying to get in touch with the previous owner and find out if it overheated in the past.
Did he just get it ?
Audrey II
Post by Audrey II »
I just read this on BE then saw the title of this thread I was expecting something very different.
http://seabreezenews.com/issue/Page_01c.pdf
1996 Trojan 440
Paul, he's had the boat for a few years.
Audrey II wrote:I just read this on BE then saw the title of this thread I was expecting something very different.
Me too... :roll:
