1970 CHRYSLER 318 V8 ENGINE - LONG or SHORT Block
How can you tell whether an engine is a long or short block?
Neil Wilson
Neil Wilson
- Stripermann2
The term short block means block only no heads on motor and when they say long block the mean a motor with heads on it thats shop talk and now a smale block is smaller than a big block and puts out less horse power And big block is bigger and puts out more horse power now if they ask you if you want to buy a 318 short block that means it has no heads block only with crank,rods,pistons and thats it hope this is helpfull.
a 318 is a small block not short or long so to speak Raymond post covers it well . now I will add to this there are 2 318 engines old and new type I put this info in a forum a few weeks ago I will copy and paste it below I have seen the old style used as late as 1970 ( possable Later )
they made 2 different 318s the first one was made in the late 50s to the mid 60s then when to the new style 318
I think the marine engines changed in 1967-70 or so .
did a liltle checking A engine 318 1957-67 ( old type)
LA engine 318 1967-2001 new type
these were the years the engines were made. may have use the left over A engine for later year marine engines .
the easiest way to tell is by the heads"
_________________
_________________
