lettering removal and bilge heat
dodgeem
Post by dodgeem »
I've used a heat gun to remove the letters but there appears to be a glue residue left. On motorcycles I've used wd-40 to remove the glue and elbow grease. I did a quick search but only found oven cleaner and I am scared of both the oven cleaner and wd-40 on the gelcoat. Any ideas?
Also, the boat is in the marina for the winter and I've been checking it daily for ice in the bilge and general well being but is there a better way to keep ice out of the bilge? A guy in the slip beside me suggested a 100 watt bulb but I was scared of gas fumes and the potential for spark from the bulb. again...any ideas?
________________________
1975 F-36
1993 Pro-Line center console
fourreins
Post by fourreins »
Lacquer Thinner will remove the sticky residue.
Peter
Post by Peter »
Please insert acceptable political or boating statement here...or not... I really don't give a crap....
JonChristman
Post by JonChristman »
I used Easy Off oven cleaner to remove painted on letters on a jetski and it was fantastic. It didn't hurt the gel coat at all. I was amazed. It also did a great job of getting off the glue residue from the second jet ski I had.
Jon
Former Owner of F-26 "Tir Nan Og"
and looking for another Trojan
alexander38
Post by alexander38 »
I used goo-gone pro. From HD. Works good if the oven cleaner worries you.
Allen Sr
Post by Allen Sr »
oven cleaner,goo gone, gum cutter none of that will hurt the gel coat especially the short length of time it will be on there.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
foofer b
Post by foofer b »
Goo gone is great . I think it can be used on almost any surface without worry, I have used it on fiberglass, but as always test first.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
g36
Post by g36 »
boatsafe heater in my f32. but i still check on my boat alot but thats also a good excuse too.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
pk
Post by pk »
To remove the sticky stuff, the glue, use 3M Citrus Cleaner. This is a very good product!
larglo
Post by larglo »
When I first joined the forum, I was concerned also about the winter and the engine freezing up, and at the time new nothing about winterizing an engine.
After posting a question and getting chewed out about putting a bulb in the bilge for fear of gas fumes I bought the Boatsafe bilge heater.
It worked great all winter. It cost an arm and a leg, but it did the job. There was one problem though I had all winter,,,,,what if the power went OFF!
This winter I found out how to winterize an engine, very easy really, but I'm also using the Boatsafe heater,,,,,,just in case!
http://www.boatownersworld.com/boatsafe ... eaters.htm
I see others put up web sites, but will add this one too.
Larry
dodgeem
Post by dodgeem »
Thanks guys, i'll give the various cleaners a go. I'll stray from the bulb and go to a heater
1975 F-36
