carburetors, what are you guys using
- guglielmo6160
my 350 Merc, is using a two barrel Rochester, having some issues with dripping down the barrels while she is idling, carb is rebuilt, and I notice some huge jets in the bowls.
Was wondering what carbs you guys are running, and has anybody else noticed this whle at idle ,
thanks
thanks
1983 10 meter express
for a 2 barrel carb Rochester is your best bet . I also have seen Holley and ford/autolite carbs used on ford marine engines with 2 barrels .
as a general rule on 4 barrel engines your will find Rochester ( Q-jet ) and Holley's on GM engines , Holley's on fords and Carter AFB ( elderbrock now) on Chrysler marine engines .
I would stick with what you have as fitting a other type can be a pain. and the Rochester 2 barrel is one of the better ones
But what ever you do . You must use a marine carb as they are vented differently a auto carb would be a ticking time bomb .
- alexander38
Had the same trouble with my stbd one. Bought a re-man and took the old one part and found that Serria didn't put the carb filter in and a pc of rubber from a dining fuel pump and gotten in the float seat , also don't over look a bad fuel pump causing this. And like the King said don't go to a different one you can bring in new troubles and drive your self nuts .
- guglielmo6160
the carb and the engine are both full marine, as this was a complete drop in unit, the carb although was new(rebuilt) Im sure, I also went through it myself, everything checks out especially the float level and there is no debris at all in the carb. Now I have to point out that this engine is using an electric pump, which is fitting to the right front of the engine. In my experiecnce to much fuel pressure will also cause this dripping int he barrels, while running.
What I did was shut down the fuel pump while the engine is running and about two seconds the dripping stopped, due to the decrease in float level. But Im not quite sold on that repair yet. And of course once the pump is plugged back in it immediately starts dripping all over again,
this is causing a rich mixture with raw, un atomized fuel being dripping into the manifold. , not to mention the price of fuel and what Im wasting.
so I guess the next step would be a fuel pressure gauge , and possibly a regulator.
Im guessing between 2-4 lbs should be a normal setup for carbs..
again, my experience is with older automobiles not marine, but Im applying the same principals to this set up,
I was just wondering if anyone had this particular problem with a Rochester before, as it is a super simple carb.
thanks (excuse my spellilngs, as its early,,lol)
Fought the same issue son the 454 in my 26. Finaly foudn the fuel pump had loots its pressure regulation and would build up pressure at speeds over 1,200RPM. Replaced it (mechanical, belt driven Mercruiser unit) and all was well (now I'm dealing with 100 gallons of old corn fuel, which I plan to separate & "polish").
Yes - 4-5psi MAX pressure! You can get a regulator from Summit racing
If you're happy with the power, keep the Rochester marine 2-barrels (it was a marine eigne purchase, correct)?
If you want more power, you can change the manifolds and put a 4-bbl on. The Qjet is very economical because its a "spread-bore" meaning its 4 venturi are different sizes (2 sizes). The 2 primary venturis are small (smaller than you 2-bbl probably), while the secondary venturis are very large (when you get that need for speed).
All other 4-bbl carbs (Holley, AFB, Motorfraft) are "square-bore", meaning all 4 venturis are the same size.
- alexander38
Aah yes a pump that's pumping to high a psi will cause this, mechanical or elec. I found that out last yr. The fuel pump on my Onan 6.5 mcck went bad I thought it was the carb, pump the elec gas pump was not shutting down when it should've and not letting the float seat .
- Sporadic User
Seems as though everyone has had this problem; I installed an adjustable regulator and a guage took care of the problem.
Word of advice... do not get a cheap one many will leak. Read the reviews of whatever you buy. I reccomend Holly I think they have one for around $65.00 on Amazon.com that will adjust from 2 psi to 6.5 psi.
Good luck.
Steve
Good luck.
Steve
1963 31' Sea Breeze; Twin Interceptors
2000 21' Lightning; Marine Power 454 jet drive
http://s1177.photobucket.com/home/sdelfino5225/index
- alexander38
Cheap = boom
- guglielmo6160
- alexander38
Hey guys seems he found the trouble, to much pressure and its keeping the needle from seating
the foam floats have got to go - brass only! Can't believe they still make them.
Fired up the Cummins today - started/ran like a top ... cruise tomorrow.
