Exhaust risers
dodgeem
Exhaust risers
Post by dodgeem »
I've done a few searches but not finding anything... I've got a 6 inch crack in the port side engine and an appointment to get the bottom painted Monday. The question is can it be welded until I can order a new one?
________________________
1975 F-36
1993 Pro-Line center console
I would not weld it should be easy to get one , what engines do you Have ? 440s
As Paul said ...if it has a crack on the outside, how do you know it's not cracked on the inside? The last thing you'd want is for coolant/water to get sucked back through an exhaust port.
Replace it.
dodgeem
Post by dodgeem »
They are 440's. I am trying to track done one locally but no luck so far.
1975 F-36
alexander38
Post by alexander38 »
no welding, you need a new set sorry to here you've got a cracked one..how did it crack ?
davidsmith
Exhaust manifold
Post by davidsmith »
E-Basic Power sells manifolds for 440`s.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
rossjo
Post by rossjo »
Cracked manifold or cracked block?
Cracked manifold = replace! Why risk it? The manifold has to come off anyway - so replace it and be safe .
dodgeem
Post by dodgeem »
New one on the way from ebasicpower.com. Thanks for the help guys.
1975 F-36
