PULPITS
raymond workman
PULPITS
Post by raymond workman »
HOW LONG AND WIDE SHOULD THE ANCHOR PULPIT BE ON A 30 FT LONG BOAT IN GENERAL IF SOMEONE WAS TO ADD ONE
rossjo
Mine
Post by rossjo »
I added a 42" x 14" x 1-3/4" pulpit to my F32 about 2 years ago. Gelcoated Fiberglass with 1.5oz mat 1708 biax material over 3/4" Marine Plywood - 28lbs ... eBay seller OUTLAW$0. He still sells them ...
http://cgi.ebay.com/ebaymotors/FIBERGLA ... dZViewItem
I added a nice Stainless anchor roller and 1/2" Stainless bolts and a heavy 316 stainless 8" cleat to finish it off.
Works great.
g36
pulpit
Post by g36 »
have you any closeup pics of your installation? i also am interested the wife is getting tired of pulling up the anchor on our f32. could you also describe how you mounted it i ll assume through the deck, backing etc? thanks
rossjo
Stainless bolts
Post by rossjo »
1/2" Type 316 Stainless bolts and an 8" cleat with through bolts to large backer plates made of 1/2" Starboard with large (2"Dia) Washers .... I'll send pix when I get a chance (hard to get pix, when its gets dark @ 5:30).
I haven't added the Windlass yet - 2008 we hope. My wife (and friends) can't do the anchor any more, so I do it - ha!
I did go to a Fortress aluminum anchor - and would recommend it to everyone! Its light, but hooks up bette rhtna the old heavy galvanized Danforth. I simply bought 1 size larger than Fortress recommend, added a type 316 Stainless, 1/2", 6' long ahcnor chain. Its light, hooks well, and much easier to pull up!
If you're on a budget - Fortress makes the Guardian series, which I use on my 18' Center Console (we lose these to rocks occasionally, so we went cheaper). FOr inshore use - I use a Cajun anchor - whihc is a 5' long pice of 3/4" Type 316 Stainless rod with a shackle at the end with a 15-20' line on it. Just drop it straight into the water, and it sitcks in the mud like glue. Just pull it up or back the bota up to remove, and it slides right ourt of the mud. VERY easy (made this myself or they're $90 online).
Not sure how thee work on hard bottom, becuse we have pluff mud and sand here.
Capt. Ross when you get a chance I would like a photo or 2 of your Pulpi
I just Bought one from the "Outlaw" today ( thanks for the link ) I would like to see how you did the roller. I belive you have my email addess
rossjo
I'll look
Post by rossjo »
I'll look for a photo tonight - or just go take a couple and send.
I used a WIndline model AR-5 Stainless bow roller ...
Anchor is a Fortress FX-23 (1 size larger than recommended) with 6' of Type 304 Stainless 5/16" PC proof anchor chain (2,425lb. working strength, 7,275lb. break strength).
I did cut out the sides (up to the wood level) to form to the the shape of the raised section around the bow, and then used plenty of 5200 beneath and to seal it. It looks factory, and the stainless roller works great.
rossjo
F32 Pulpit Pix
Post by rossjo »
F32 Trojan Pulpit Pix:
Still need to pull those ugly anchor chocks off of my deck. I got rid of my deck mounted red/green nav lights and went with bridge mounted LED units - much cleaner look.
I plan to rpeplace the crusty stainless(or are they chromed brass?) fittings with new Type 316 Stainless fittings soon (?when?) as well!
g36
pulpit
Post by g36 »
thanks rossjo for the pics, i think i'll do this to my f32. my wife will be much happier
Looks Good Capt. Ross looks like that will be the first project of the new year . My pulpit should be here soon ,
g36 you have mail
Almost 3 1/2 years later I put the pulpit on , I changed mine and put the roller at the front ( covered and filled the hole ) and then left it out back in the shop for about 3years , I was in no hurry
g36
Post by g36 »
hey i put mine on last year along with a new windlass this year. the wife really loves the windlass
also if i didnt say it then thanks rossjo for the pics way back when. it was nice having a real good pic of the finished job. i knew exactly what needed to get done
prowlersfish you have mail back
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
